Where can I find the images referenced in the samples
1153
8
03-23-2012 07:40 AM
GregoryDillon
Where can I find the images referenced in the samples  (ie the images directory).
FYI:
This link does not appear to be working on your site and I was hoping it would tell me how to get these images.
http://help.arcgis.com/en/webapi/jav...mple_using.htm
derekswingley1
You can see the path to images in the sample source or by using your browser's dev tools to inspect page elements in the live sample.
What image(s) are you looking for? Can you post a link to a sample that uses images you want to use?
GregoryDillon
How about http://help.arcgis.com/en/webapi/javascript/arcgis/demos/mobile/mobile_soilmap.html
When I select View Source in IE I get as the path
var symbol = new esri.symbol.PictureMarkerSymbol("images/bluedot.png",40,40);
What dev tool are you suggesting?
GregoryDillon
How about http://help.arcgis.com/en/webapi/javascript/arcgis/demos/mobile/mobile_soilmap.html[/url]
MattMoyles
It's a relative path. The file you want is http://help.arcgis.com/en/webapi/javascript/arcgis/demos/mobile/images/bluedot.png
Place it in a dir /images relative to your .html page.
If you are using IE9+ just hit F12. If you are using FIrefox or Chrome look at Firebug.
JeffPace
Firefox with firebug
derekswingley1
Good replies all around. Here's the url for the image:  http://help.arcgis.com/en/webapi/javascript/arcgis/demos/mobile/images/bluedot.png
I'll give a shout out chrome's dev tools, see attached screen shot.
GregoryDillon
Thanks!   This was very helpful!
derekswingley1
Glad we could help. You should mark one of the posts above as an answer, probably the one from mmoyles.
