Can I run a find task from a dropdown list of county names?
1611
03-22-2012 01:31 PM
TracySchloss
Honored Contributor
I'm very new to HTML/JavaScript and I'm surprised not to find an example out there already for this.  I would like to let the user pick a county from a list and zoom to that county.  I see examples where the users can enter in the name into a text input, but there are a lot of issues with spelling and I'd rather let them choose.
I have the dropdown list, but the value selected isn't making it into my doFind function.
I've deleted a lot of our counties in this example - Missouri has over 100!
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
    <head>
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
        <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" />
        <!--The viewport meta tag is used to improve the presentation and behavior of the samples
        on iOS devices-->
        <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
        <title>zoomCountyByName</title>
        <style type="text/css">
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    </style>
    <script type="text/javascript">
      djConfig = {
        parseOnLoad: true
    </script>
        <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.7/js/dojo/dijit/themes/claro/claro.css">
        <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.7">
        </script>
            dojo.require("esri.map");
            dojo.require("dojox.grid.DataGrid");
            dojo.require("dojo.data.ItemFileReadStore");
            dojo.require("esri.tasks.find");
            dojo.require("dijit.layout.BorderContainer");
            dojo.require("dijit.layout.ContentPane");
            dojo.require("dijit.form.Button");
            dojo.require("dijit.form.ComboBox");
            var map;
            var findTask, findParams;
            var countyName, mySelect;
            function init(){
                              var spatialReference = new esri.SpatialReference({
                    wkid: 102100
                var startExtent = new esri.geometry.Extent(-10583000, 4287025, -9979000, 4980462, spatialReference);
                map = new esri.Map("map", {
                    extent: startExtent
                var streetMapLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
                map.addLayer(streetMapLayer);
                //Create Find Task using the URL of the map service to search
                findTask = new esri.tasks.FindTask("http://gis.dhss.mo.gov/arcgis/rest/services/county_simple/MapServer");
                //Create the find parameters
                findParams = new esri.tasks.FindParameters();
                findParams.returnGeometry = true;
                findParams.layerIds = [0];
                findParams.searchFields = ["NAME", "NAME2"];
                findParams.outSpatialReference = map.spatialReference;
                dojo.connect(map, 'onLoad', function(theMap){
                    //resize the map when the browser resizes
                    dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
            function doFind(){
                //Set the search text to the value in the box
                countyName = dojo.byId("mySelect").value;
                findParams.searchText = countyName;
                // findParams.searchText = dojo.byId("mySelect").value;
                findTask.execute(findParams, showResults);
            function showResults(results){
                //This function works with an array of FindResult that the task returns
                map.graphics.clear();
                var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98, 194, 204]), 2), new dojo.Color([98, 194, 204, 0.5]));
                //create array of attributes
                var items = dojo.map(results, function(result){
                    var graphic = result.feature;
                    graphic.setSymbol(symbol);
                    map.graphics.add(graphic);
                    return result.feature.attributes;
                //Zoom back to the initial map extent
                var selectedExt = graphic.geometry.getExtent();
                map.setExtent(selectedExt);
            dojo.addOnLoad(init);
        </script>
    </head>
    <body class="claro">
        <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;margin:0;">
            <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" style="height:40px;">
                <select id="mySelect" data-dojo-type="dijit.form.ComboBox" onchange="doFind();" >
                    <option>Adair</option>
                    <option>Andrew</option>
                    <option>Atchison</option>
                    <option>Audrain</option>
                    <option>Barry</option>
                    <option>St. Charles</option>
                    <option>St. Clair</option>
                    <option>St. Francois</option>
                    <option>St. Louis</option>
                    <option>St. Louis City</option>
                    <option>Ste. Genevieve</option>
                    <option>Stoddard</option>
                    <option>Stone</option>
                    <option>Sullivan</option>
                    <option>Taney</option>
                    <option>Texas</option>
                    <option>Vernon</option>
                    <option>Warren</option>
                    <option>Washington</option>
                    <option>Wayne</option>
                    <option>Webster</option>
                    <option>Worth</option>
                    <option>Wright</option>
                </select>
            </div>
                <div id="map" style="width:900px; height:600px; border:1px solid #000;"></div>
            </div>
    </body>
</html>
ReneRubalcava
Esri Frequent Contributor
Actually, this will work
dojo.connect(dijit.byId("mySelect"), "onChange", function(value){
 console.log("value = ", value);
TracySchloss
Honored Contributor
Where does this go?  Does it matter?  I'm used to Flex and Actionscript and the order doesn't seem to matter as much there as it does in javascript.
Also, does this mean I need to remove the onchange from the <select> tag?
ReneRubalcava
Sorry, put it in your init function, after the dojo.connect for the map.
