Centre map
1791
10
03-13-2012 06:37 AM
CliveSwan
I want the map to centre the map, when the user clicks the map.
I have added a line to center the map, is not working??
The code is below, any suggestions???
//Zoom to the parcel when the user clicks a row
function onRowClickHandler(evt) {
    var foundItem = grid.getItem(evt.rowIndex).obj_ID;
    var selectedItem;
    dojo.forEach(map.graphics.graphics, function(graphic) {
        if((graphic.attributes) && graphic.attributes.OBJECTID === foundItem[0]) {
            selectedItem = graphic;
            switch (graphic.geometry.type) {
                case "point":
                    graphic.setSymbol(pictureMarkerSymbol);
                    break;
                case "polyline":
                    graphic.setSymbol(selectedLineSymbol);
                    break;
                case "polygon":
                    graphic.setSymbol(selectedPolySymbol);
                    break;
    var selectedItemExtent = selectedItem._extent.expand(0.2);
    map.setExtent(selectedItemExtent);
    ///map.centerAndZoom(selectedItemExtent, 0.5);
    map.centerAt(selectedItemExtent);
CliveSwan
I created a centerMap function, below. It does not do anything???
Any suggestions what or why it is not working??
function recenterMap(selectedItemExtent) {
HemingZhu
    var selectedItem;
                case "point":
                    break;
                case "polyline":
                    break;
                case "polygon":
                    break;
Change graphic.attributes.OBJECTID === foundItem[0] to graphic.attributes.OBJECTID === foundItem
CliveSwan
Hi Zhu,
I changed the line as you suggested to:
The map does not recenter where the user clicks???
It does not move or recenter???
HemingZhu
Hi Zhu,
map.centerAt is only for point. if your graphic's geometry is of polyline or polygon. you might have to use var selectedItemExtent = selectedItem.geometry.getExtent(); map.setExtent(selectedItemExtent);
CliveSwan
Hi Zhu,
I am selecting a Point feature. I amended the code as you suggested, clicked on various points, the map does not recenter??
Is the code above clear enough??
Any other suggestions??
CliveSwan
I have the imageWindow appearing in the UpperLeft window.
I want to move the imageWindow to the UpperRight.
I added the following, does not move the imageWindow to UpperRight??
show: function(location) {
    // Is location specified in map coordinates?
    if (location.spatialReference) {
      location = this.map.toScreen(location);
    map.infoWindow.show(location, InfoWindow.ANCHOR_UPPERRIGHT);
    // Position 10x10 pixels away from the
    // requested location
///    dojo.style(this.domNode, {
///      left: (location.x + 10) + "px",
///      top: (location.y + 10) + "px"
I commented out the Position 10px, imageWindow on the edge did not show fully.
Any suggestions, to get the Anchor working??
CliveSwan
I edited the addIdentifyResultsToMap function.
I added two lines (below)
map.infoWindow.setFixedAnchor(infoWindow.ANCHOR_UPPERRIGHT);
map.infoWindow.show(infoWindow.ANCHOR_UPPERRIGHT);
I get an error "addIdentifyResultsToMap error, details: [object error]
Any suggestions??
if(tc.hasChildren()) {
                tc.domNode.style.display = 'block';
                tc.domNode.style.visibility = 'visible';
                tc.startup();
                tc.resize();
                map.infoWindow.setTitle("Identify Results");
                map.infoWindow.setContent(tc.domNode);
                map.infoWindow.resize(360, 200);
                map.infoWindow.show(event.screenPoint, map.getInfoWindowAnchor(event.screenPoint));
                flushThis("tabs");
                setCursorByID("map", "default");
            hideLoading();
CliveSwan
I have used the same syntex for the show(map.getInfoWindowAnchor) and setFixedAnchor
I do not get an error with show() line.
I get an error with setFixedAnchor() line??
/// SET THE POSITION OF THE IMAGEWINDOW - UPPER RIGHT
map.infoWindow.setFixedAnchor(map.infoWindow.ANCHOR_UPPERRIGHT);
I have copied an example from the examples and still get an error??
map.infoWindow.setFixedAnchor(esri.dijit.InfoWindow.ANCHOR_UPPERRIGHT);
Can anyone spot an error??
CliveSwan
Got the map.centre working.
The code below in the function addIdentifyResultsToMap(idResults, event)
              /// PAN & CENTRE MAP ON SELECTED POINT
                  var centerPointScreen = map.toScreen(event.screenPoint);
             /// PAN MAP TO NEW centerpoint (in Map coordinates)
                 centerPoint = map.toMap(event.screenPoint);
                 map.centerAt(centerPoint);
