InfoWindow shows thumbnail in FF but not IE
1518
03-13-2012 01:55 PM
by Anonymous User
Not applicable
Original User: [email protected]
I have graphics on a map that when clicked will pop up an InfoWindow containing a title and a thumbnail image.  However the thumbnail only appears in FF.  It doesn't appear in IE8 or IE9.
Here's the code:
                        var iconUrl = dojo.moduleUrl("com.esri.solutions.jsviewer", "assets/images/icons/i_pushpin.png").path;
                        var smallIconUrl = com.esri.solutions.jsviewer.util.getSmallIcon(iconUrl);
                        var pms = new esri.symbol.PictureMarkerSymbol(smallIconUrl,20, 20);
                        var point = new esri.geometry.Point(xVal, yVal, this.srWGS84);
   var title = item.prodname;
                       //example item.browseURL = 'http://tdds.cr.usgs.gov/browse/ortho/14R/NT/14RNT430640_200301_0x1500m_CL.jpg'
   var content =  item.tileName + "<br/><img width='200' height='200' src='" + item.browseUrl + "'/>";
   var attrs = {
    "title": title,
    "content": content
   var orthoTileInfo = new esri.Graphic(point, pms, attrs);
                        this.map.graphics.add(orthoTileInfo);
I'm using ArcGIS JS API 2.3
Any ideas?
I've attached screenshots from each browser.
todddoerr
Disregard.  I found the issue.
The InfoPopup widget has explicit code in it removing any img tags if browser is IE or Opera.
Here's the explicit code:
                                        if (dojo.isIE || dojo.isOpera) {
                                        dojo.query("img", this.contentNode).forE
ach( function(img) {
                                                img.parentNode.removeChild(img);
FYI:  InfoPop is a part of a sample viewer ESRI posted to their Code Gallery a few years ago when ArcGIS API for Javascript first came out.  We took it and ran with it.  We have kept it current with the latest API version.  Maybe InfoPop didn't behave properly with img tags at version 1.2 and thus the code above.  But images appear without any problems now at 2.3.
by Anonymous User
Not applicable
Original User: jeff.pace
We did the same.
http://www.mymanatee.org/gisapps/mapviewer/index.jsp?type=landdevelopment&widgetOn=Basemap%20Gallery...
There is a sample of some of the modifications we have made.  Happy to share ideas.
