FlexViewer, config.xml and GeoServer WMS
4334
01-27-2012 03:49 AM
StephenHallett
Hope someone can help. I am trying to get the FlexViewer (2.5) to use a wms feed from GeoServer (2.1.0) with no luck.
I am just trying to get one of the default GeoServer layers (tiger:tiger_roads) to show up
In the FlexViewer config.xml, an an operational layer I am trying:
<layer label="Tiger_Roads" type="wms" visible="true" alpha="0.6" skipgetcapabilities="true"
         crs="EPSG:4326" format="image/png" visiblelayers="tiger:tiger_roads"
         url="http://<server>:8080/geoserver/tiger/wms"/>
In Geoserver, the valid wms URL is
http://<server>:8080/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=tiger:tiger_roads&styles=&bbox=-74.02722,40.684221,-73.907005,40.878178&width=317&height=512&srs=EPSG:4326&format=image/jpeg
Menu item appears, but with no data and 'zoom to layer' zooms out to whole world. Any help appreciated!
StephenHallett
Dasa - thanks, I solved my problem - in the end the usual issue of projections!!
First, Charles Proxy & HttpFox are good suggestions. I actually used Chrome which has similar http traffic inspection tool (F12 -> Developer tools -> Resources/Network). Great for inspecting responses from wms requests. Using this I saw the bounding box coordinates were the problem (for FlexViewer they need to be in projected web-mercator not geographic wgs84). Changing the FlexViewer wkid as below solved problem.
<layer label="Tiger_Roads" type="wms" visible="true" skipgetcapabilities="true"
wkid="3857" format="image/png" visiblelayers="tiger:tiger_roads" version="1.1.0"
The other useful clue was in the forum discussion on projections here http://forums.esri.com/Thread.asp?c=93&f=984&t=288607
DasaPaddock
StephenHallett
Dasa - thanks for your reply. Still no luck I'm afraid. Here is current, edited connection string:
crs="EPSG:4326" format="image/png" visiblelayers="tiger:tiger_roads" version="1.1.0"
The Geoserver instance is on the same server as flexviewer to try to sidestep crossdomain issues. Geoserver is serving up wms data correctly using full url posted earlier. Is there any diagnostic I can use to see if FlexViewer is receiving anything?
DasaPaddock
Try a tool like Charles Proxy or HttpFox to see the HTTP request and response.
StephenHallett
