ISCommand for Service Overviews
834
04-06-2010 10:44 AM
MatthewMoore
I am trying to use ISCommands to build image services. I am stuck on getting the ISCommands to successfully build service overeviews and/or derived tiles.  Someone look at my commands and the error it returns to let me know what I am doing wrong.  It looks like the service editor is having trouble creating the directory for the SO and DT.
1)Create
ISCommand.exe CreateService --ISDef=E:\Imagery\AFCENT\United_Arab_Emirates\Al_Dhafra\Image_Services\al_dhafra_15jan2010.ISDef ???-BitDepth=8 ???-NBands=3 ???-Colorspace=1 ???-SrsPrj=PROJCS["WGS_1984_UTM_Zone_38N",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.2572235630016]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",500000.0],PARAMETER["false_northing",0.0],PARAMETER["central_meridian",45.0],PARAMETER["scale_factor",0.9996],PARAMETER["latitude_of_origin",0.0],UNIT["Meter",1.0]]
2)Add Rasters
ISCommand.exe AddSID --ISDef=E:\Imagery\AFCENT\United_Arab_Emirates\Al_Dhafra\Image_Services\al_dhafra_15jan2010.ISDef\ImageService.ISDef --Filters=*.sid --Files=E:\Imagery\AFCENT\United_Arab_Emirates\Al_Dhafra\MrSid\al_dhafra_15jan2010_wgs84_utm40N_50cm_r1c1_sid.sid,E:\Imagery\AFCENT\United_Arab_Emirates\Al_Dhafra\MrSid\al_dhafra_15jan2010_wgs84_utm40N_50cm_r1c2_sid.sid,E:\Imagery\AFCENT\United_Arab_Emirates\Al_Dhafra\MrSid\al_dhafra_15jan2010_wgs84_utm40N_50cm_r2c2_sid.sid,E:\Imagery\AFCENT\United_Arab_Emirates\Al_Dhafra\MrSid\al_dhafra_15jan2010_wgs84_utm40N_50cm_r2c1_sid.sid
3)Build
ISCommand.exe BuildService --ISDef=E:\Imagery\AFCENT\United_Arab_Emirates\Al_Dhafra\Image_Services\al_dhafra_15jan2010.ISDef\ImageService.ISDef ???-ValidateRasterSrc=True --ValidateRPDefs=False --OutputProperties=False --ViewPointShift=False --ComputePixelSizeRanges=True --ExtractMetadata=False --DeriveBoundary=True --DeriveImages=False
4)Service Overviews
ISCommand.exe DefineServiceOverviews --ISDef=E:\Imagery\AFCENT\United_Arab_Emirates\Al_Dhafra\Image_Services\al_dhafra_15jan2010.ISDef\ImageService.ISDef --OutputFolder=ISDef=E:\Imagery\AFCENT\United_Arab_Emirates\Al_Dhafra\Image_Services\al_dhafra_15jan2010.DerivedImages\SO ???-OptimumNRows=5120 ???-OptimumNCols=5120 ???FormatName=TIFF --CompressionMethod=None -???CompressionQuality=70 --TileSize=256 ???-PixelSize=0.6 --OverviewFactor=2 --SamplingMethod=Bilinear
5)Build Service *This is where the error occurs
ISCommand.exe BuildService --ISDef=E:\Imagery\AFCENT\United_Arab_Emirates\Al_Dhafra\Image_Services\al_dhafra_15jan2010.ISDef\ImageService.ISDef ???-ValidateRasterSrc=True --ValidateRPDefs=False --OutputProperties=False --ViewPointShift=False --ComputePixelSizeRanges=True --ExtractMetadata=False --DeriveBoundary=True --DeriveImages=True
Error Returned:
[DerivedRasterGenerator.DerivedRaster.CreateDerivedRasters : 009920] Error: Cannot create the output directory for 'ISDef=E:
\Imagery\AFCENT\United_Arab_Emirates\Al_Dhafra\Image_Services\al_dhafra_15jan2010.DerivedImages\SO\10040516293993600000.tif'
2010-04-06T14:33:13.984 : [ImageServiceCore.ImageService.Close] SummaryUnloadService||C:\Documents and Settings\Matt\Local Settings\Temp\3\tmp155.tmp|
al_dhafra_15jan2010|2010-04-06T14:33:13.687|2010-04-06T14:33:13.812|9|0.152090|0||
2010-04-06T14:33:13.984 : [ISCommand : FFFFFFFF] Error: Command failed: 'DerivedImageGenerator'
2010-04-06T14:33:13.984 : [ISCommand : FFFFFFFF] Error: Could not complete execution of all commands.
2010-04-06T14:33:13.984 : [Global.CommandDispatcher.Execute : 00F407] Error: Execution of commands has been halted.
Anyone have any ideas?
MatthewMoore
i answered my own question. my syntax for my output folder was wrong.
original:
OutputFolder=ISDef=E:\Imagery\AFCENT\United_Arab_E mirates\Al_Dhafra\Image_Services\al_dhafra_15jan20 10.DerivedImages\SO
correct:
OutputFolder=E:\Imagery\AFCENT\United_Arab_E mirates\Al_Dhafra\Image_Services\al_dhafra_15jan20 10.DerivedImages\SO
