Option to merge multiple feature reports
1442
10-13-2020 01:12 PM
JamesFaron
Does or will the survey123 module for python enable a parameter for the selection to 'Merge' multiple reports in a single file? In other words, in the survey.generate_report parameters can or will one be able to specify 'merge' to merge multiple reports into a single file?
Shwu-jingJeng
Hi James,
The merge function is not available in the current release but will be supported in the next release. Please check it back again when we release the next version for feature report rest API.
JamesFaron
Hi Shwu-jing,
Thanks for that information. Is there a time frame established yet for the release of the next version?
Shwu-jingJeng
Hi James,
The parameter "mergeFiles" as a REST API parameter is already available for a few releases, but it's not available in Python API yet. The possible availalbe timeframe would be sometime near the Dev Summit next year. But please check again when the date is closed as this is just a tentative estimation timeframe.
