filter data based on date and time field
4781
09-28-2020 05:35 AM
ahmadhasan3
If i want to edit date field  using smart widget i will see a drop list for time along with the calendar, but when i want to filter the data based on the same date field i can filter based on the date only, is there any way to filter the data based on the date and time ? can i show the same drop list for time  similar to the smart edit widget ?
TonghuiMing
Hi Ahmad,
By taking a closer look at your screenshot, I just realize that this is an on-the-fly filtering function from the Attribute Table (runtime & custom filtering).
We do not support time-specific attributes filtering for custom filters (like in the Attribute Table or the Custom Filter inside a Filter widget) - see a Note in Filter widget—ArcGIS Web AppBuilder | Documentation
If you want the time options to display for users, it can be achieved by the "ask for values" option inside a Filter widget (or Query depending on your needs) and configure it in the widget setting instead:
  • Configure inside the widget setting panel:
Configure a Filter widget
  • Filter by time:
Filter by time
  • Custom filter does not support time-specific filtering:
TonghuiMing
In Web AppBuilder, the filter component honors the date/time settings from the data/map and there are two ways to customize them:
  • You can edit the time attribute prior to publishing the service
  • You can modify the date format in map viewer > configure pop-up > configure attributes > Format
Once the service supports time attributes, then it will show in the setting panels.
Best,
Tonghui
ahmadhasan3
i already configure the pop-up to show the time , but still i can't filter the data based on the date and time.
TonghuiMing
Hi Ahmad,
  • Filter by time:
Filter by time
waynecoffey2
Hi  Tonghui, I have set my filter up as you have. At first if I just set up the date as ask for values I can save and use the filter but when a configure it to additionally filter the time variables the dialog will not let me save - it just freezes with no error warnings. I assume this due to something with the new filter variable and how I configured them. If I don't use ask for values I can save it.
