SyntaxError when trying to open my survey
1205
09-27-2020 06:32 AM
AlejandroMadrigal
Hi everyone! I made a form that calculates location from a choice list. It gisves no problems whe you convert it into a simulated form, neither when you publish it.
But when you try to open the published durvey, it was a warning "SyntaxError"Failed to excecute 'querySelectorAll' on Élement': 'datalist(name of form)sector > option' is not a valid selector.
Could any body help me with this? why did'nt give the warning before open it?
Thanks a lot in advance!
#survey123
JamesTedrick
Esri Esteemed Contributor
Hi Alejandro,
It would be helpful if you could share your form.  I will note the web form can be very particular on the format of calculations - look at the 'Calculate location from CSV' example to see the proper calculation format.
by Anonymous User
Not applicable
Hi James,
I'm not sure if Alejandro shared his form to help you find a solution but I am having a similar issue with the same error message.
I have been able to locate the issue to my appearance cell for a 'select_one' question type as the error only occurs if I have selected the 'autocomplete' appearance. This error only has arisen after I made amendments to other aspects of the form as this question was working previously.
Happy to share my form to help to find a solution to this.
Neil
