Assignment Integrations table in New Workforce
1478
08-05-2020 12:40 PM
by Anonymous User
Not applicable
I have two Survey123 integrations in a project I created in the new version of Workforce that link to different surveys based on Assignment Type. I typed different values in the Prompt field, however, the mobile app will only show the first value no matter the assignment type. I experience the issue using the iOS version of the new mobile app. I have not tried Android.
Is this a known issue or limitation?
CraigGillgrass
ok, thanks Matt.
I've been able to repro it; this is a bug.  We'll look at getting this into our release to support Portal; which is slated for later this month.
Craig
CraigGillgrass
Hi Matt,
I'm not entirely following the scenario you're running into.  Please let me know if my summary below is correct:
  • You created two Survey123 integrations
    • Integration 1 was with Assignment Type A
    • Integration 2 was with Assignment Type B
  • Each integration should launch Survey123 with a different survey
  • You edited the Prompt field in the Assignment Integrations table so that each of the two Survey123 integrations would have a different prompt
  • Using iOS; when you open an assignment with Type B, it will show the integration for Type A.
Do I have that correct?
If not and you're able to add screenshots that might help.
Craig
by Anonymous User
Not applicable
Yes, exactly correct.
by Anonymous User
Not applicable
It opens the correct survey... even with the wrong prompt.
CraigGillgrass
ok, thanks Matt.
Craig
