Exporting Related Feature Classes
1409
07-14-2020 07:06 AM
MKF62
In ArcMap you could use the Extract Data Wizard to export related feature classes to a new geodatabase and copy the schema of that geodatabase along with it. How do you do that in ArcGIS Pro? I can't find a suitable tool. Is the only way to do it to copy the entire GDB?
Tags (1)
Robert_LeClair
Esri Esteemed Contributor
Molly - the closest thing I could find is the Extract Data by Feature GP tool has many similar features to the ArcMap "Extract Data" command.  Hope this helps!
JillHalchin
That looks similar, although it doesn't allow you to manually select the features, which I need to do.  However, the tool is not available for me to even try because we don't have the Production Mapping license.
