Returning Original Value in Field Calculator Python Reclass
1749
01-05-2022 11:42 AM
Labels (2)
ChrisSpadi
I am reclassifying a integer field with the following code in field calculator:
Reclass(!Field!)
# Reclassify values to another value
# More calculator examples at esriurl.com/CalculatorExamples
def Reclass(arg):
if arg is None:
return None
elif arg <= 0:
return None
elif arg >= 1:
return 1
return arg
___________________________________________
For the last elif, I would like to return the original value being evaluated.  What do I need to replace 1 with in order to get the original value?
If I remove 'elif arg >= 1 and return 1', all the fields return None. Probably real simple but cant seem to find solution on any of the forums.
JayantaPoddar
What if you remove just the following line from the codeblock?
return 1
or you could have the codeblock like
def Reclass(arg):
if arg >= 1:
return arg
else:
return None
Think Location
JayantaPoddar
return 1
def Reclass(arg):
if arg >= 1:
return arg
else:
return None
Think Location
ChrisSpadi
Thanks.
