Better Bus Buffers Input error
2736
10
07-14-2020 06:21 AM
RaunaqSaboo
Hi
I am working with GTFS dataset and I am trying to use the Better Bus Buffers toolbox. However, while using the preprocessing GTFS toolbox, I cannot upload the GTFS directory and cannot mention the location for output SQL database. I am using ArcGIS Pro. I am getting the following error:
ERROR 032659 Traceback (most recent call last):
File "<string>", line 94, in updateMessages
AttributeError: module 'ToolValidator' has no attribute 'check_input_gtfs'
Any ideas on how to fix this?
Thanks in advance
Tags (1)
RaunaqSaboo
It worked after a software update. Seems like that was the issue
MelindaMorang
Hmm, that's an odd error.  The ToolValidator.py module definitely has that function, and I just tested it on my own machine with ArcGIS Pro, and it's working fine.  My guess is that something happened to the BetterBusBuffers toolbox code on your machine.
Please delete your copy of BetterBusBuffers, including all the associated .py files, and download a fresh copy here: http://arcg.is/0yr9fr
If you need to move it to some other location on your computer after downloading and unzipping it, be sure to move the entire parent folder so that all the associated scripts and other files stay together.
RaunaqSaboo
Hi Melinda, Thanks for your reply. I tried that but I am getting the same problem again. Is there any other fix?
MelindaMorang
Can you tell me what version of ArcGIS Pro you're using?
Also, are you running the tool from within Pro, or is it in a python script or a model or something?
RaunaqSaboo
I am using ArcGIS Pro 2 and I am running the tool from within Pro.
MelindaMorang
What number does it say on the About page?
RaunaqSaboo
MelindaMorang
Glad to hear it!  There was some issue with ToolValidator several Pro releases back, but I didn't know it affected this tool.  My apologies for your trouble.
RaunaqSaboo
Hi
Turns out that the issue has arisen again. The software version is 2.5.2. The tool ran once successfully. However, this time the error is:
File "<string>", line 148, in updateMessages
AttributeError: module 'ToolValidator' has no attribute 'check_SQLDBase'
Any fix for this?
MelindaMorang
Here's something else to try.
  1. Close ArcGIS Pro if it's open.
  2. In Windows Explorer open the folder where your BetterBusBuffers files are stored.
  3. Delete the __pycache__ folder if it exists:
  4. Delete all files in that folder with a .pyc or .pyt.xml extension. Do not delete any other files.
  5. Try running the tool again.
If that doesn't fix it, let me know, and we'll keep trying.
