Better Bus Buffers Input error
4015
10
07-14-2020 06:21 AM
RaunaqSaboo
Hi
I am working with GTFS dataset and I am trying to use the Better Bus Buffers toolbox. However, while using the preprocessing GTFS toolbox, I cannot upload the GTFS directory and cannot mention the location for output SQL database. I am using ArcGIS Pro. I am getting the following error:
ERROR 032659 Traceback (most recent call last):
File "<string>", line 94, in updateMessages
AttributeError: module 'ToolValidator' has no attribute 'check_input_gtfs'
Any ideas on how to fix this?
Thanks in advance
Tags (1)
RaunaqSaboo
Hi
On deleting the files, the tool was not working so I had to repair it (from an option in the toolbar). Even then it did not work. Then on closing the software and opening it again, it did work.
So I am not really sure how it is working, but sometimes it does work.
Although it does not seem to be a permanent fix.
