ArcPy: Import data into Feature Dataset within Geodatabase
6677
7
07-09-2020 11:28 PM
BrianSteiner1
I have a Geodatabase-file "mygdb.gdb" with a Feature Dataset therein, "mygdb.gdb\fds". How can I move files into that Feature Dataset with ArcPy? Please see picture: I want to move the shapefile "myshp.shp" and the raster "myraster" into that Feature Dataset with ArcPy.
Example of data to insert into Feature Dataset
DanPatterson
MVP Esteemed Contributor
The requirements and data types are listed in the help
Feature datasets in ArcGIS Pro—ArcGIS Help | Documentation
... sort of retired...
BrianSteiner1
On that page, I can't find any information about how to handle Feature Datasets with ArcPy. Where is a description how to move an external shapefile or raster into the Feature Dataset with an ArcPy-command?
JoeBorgione
BrianSteiner1
This explains how to move shapefiles into a geodatabase (in my example: mygdb.gdb). However, I don't understand how to move shapefiles into a Feature Dataset within a geodatabse (in my example: mygdb.gdb\fds).
DavidPike
MVP Notable Contributor
import arcpy
#path to input shapefile to be transferred to fgdb feature dataset
in_shp = r'C:\myshapefile.shp'
#path to output fc within feature dataset
#will likely error if .shp and feature dataset have different projections
out_fc = r'C:\mygdb.gdb\myfeaturedataset\myfeatureclass'
#run copy features tool
arcpy.CopyFeatures_management(in_shp, out_fc)
BrianSteiner1
Thank you David Pike. I understand from your answer that the Feature Dataset within a Geodatabase is for Feature Files of same projection only. It is neither for Feature Files with another projection nor for Raster Files. My problem was, that I was trying to import a Raster File which is not allowed.
DanPatterson
That information was on the link I sent
