Arcpy - what sddraft property control the "build your cache manually" option when publishing a map service
1156
07-09-2020 06:08 AM
MaximeDemers
I am using arcpy to automatize the publishing of map services. I want to toggle on the "build your cache manually" option but I can't find the part in the sddraft that controls that option.
Someone knows what sddraft property control the "build your cache manually" option when publishing a map service?
Thank you
DanPatterson
MVP Esteemed Contributor
MapServiceDraft—Sharing module | Documentation as an example, don't see any "toggle" or parameter, but the code example in the "Modify SDDraft example" provides methods for how to edit one
... sort of retired...
