Open ArcGIS published TIF file and transform
2188
07-05-2020 11:53 PM
NadieWhitelaw
I recently downloaded a dataset from a Chinese geodata site (Global Change Research Data Publishing & Repository )
The published data is in the for of a .TIF raster file with some metadata:
The data looks something like this (Population density per KM)
Apparently this dataset was published in ArcGIS which I found a reference to in XXX.tif.aux.xml. The rest of the metadata files were encoded and are probably only readable from ArcGIS.
Is it possible to load this data using the Python API and transform it to another co-ordinate space? Ideally, I would like to transform it to the WSG-84 Space and and do some calculations using some other province/border shaperfile data.
Tags (4)
NadieWhitelaw
Hi. I solved this problem, there are some python libraries which are able to transform the data, I thought the GeoTIF spec was encoded, turns out it isn't
About the Geotiff (.tif) Raster File Format: Raster Data in Python | Earth Data Science - Earth Lab
