Validation Text Box
2172
04-02-2011 02:36 PM
JosephSaltenberger
I have implemented the validation text box for the editing Widget using the JavaScript API, but it does not prevent invalid entries from submission into the database. The input text box on the attribute inspector will have a warning showing the attribute is not valid, but if the user submits the change, it still goes through.
I believe I need to use dijit.form.form widget to ensure invalid attributes are not submitted, but I am not quite sure how to implement this.
Any examples out there?
Thanks.
HemingZhu
Thanks.
First of all, if you set wrong type of data for an attribute field for example put a text string info a field with double type, the field will not accept a value. Secondly, if your specified a domain and/or subtypes for the attribute field, the field will not accept a value that is not in that domain or subtypes. In both cases the field value will not updated. Thirdly, you could further constrict the entries by code logice using validation like in your case. Something like the following:
dojo.connect(attInspector, "onAttributeChange", function(feature, fieldName, newFieldValue) {
            // specify thefieldName you want to further validate
            if (fieldName ==thefieldName)
                var regularExpression = /^\d+(\.\d+)?$/;  //for example a positive value
                if ( newFieldValue.match(regularExpression))
                     feature.attributes[fieldName] = newFieldValue;
                     feature.getLayer().applyEdits(null, [feature], null);
                else
                     //alert("invalid entries for field " +fieldName);
                     return;
             else
HemingZhu
Thanks.
                else
                     return;
             else
JosephSaltenberger
Your third point is the answer I was hoping for... the "onAttributeChange" event is what I was looking for.
