Problem With ArcGIS Server Services
795
04-07-2011 01:21 AM
ZeeshanKhan
I am new to  web mapping application with ArcGIS Java Script API, I build a page its works fine on Local, but when i go over internet, it doesn't show my Layers only Google Background image, I am giving my Live IP address to connect Services, These services can be viewed but i am not able to access these services through Web Application.
I am pasting my code below.
________________________________________________________________________________
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xmlns:v="urn:schemas-microsoft-com:vml">
  <head>
    <title>ArcGIS</title>
    <meta http-equiv="content-type" content="text/html; charset=UTF-8"/>
    <script src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAoCCuxJYvQKuOME9a3Fc8KhS3iegp0cxLQXAJedXkaj3wQFF..." type="text/javascript"></script>
    <script src="http://serverapi.arcgisonline.com/jsapi/gmaps/?v=1.6" type="text/javascript" ></script>
    <script type="text/javascript">
    var gmap = null;
    function initialize() {
      gmap = new GMap2(document.getElementById("gmap"));
      var centerat = new GLatLng(31.592, 71.014);
      gmap.addControl(new GLargeMapControl());
      gmap.addControl(new GMapTypeControl());
      gmap.setCenter(centerat, 6);
      var admin = new esri.arcgis.gmaps.DynamicMapServiceLayer
        ("http://0.0.0.0(myliveip)/ArcGIS/rest/services/javatest/admin_boundries/MapServer",
        null, 0.75, dynmapcallback);
    function dynmapcallback(mapservicelayer) {
      gmap.addOverlay(mapservicelayer);
    </script>
  </head>
  <body onload="initialize();" onunload="GUnload();">
    <div id="gmap" style="width: 100%; height:550px;"></div>
  </body>
</html>
SiqiLi
by Esri Contributor
1.Please add the reference of ArcGIS API for JavaScript into HTML HEAD element of your HTML page
  e.g.  <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.2"></script>
2. Please create a map variable using esri.Map class. Specify value "gmap" as the name of the DIV element that will contain the map.
   e.g.   var map = new esri.Map("gmap");
3. Please create a mapservicelayer variable using using the ArcGISDynamicMapServiceLayer constructor.
   e.g. var mapservicelayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://<server name>/ArcGIS/rest/services/javatest/admin_boundries/MapServer",{"opacity":0.75});
4. Add the mapservicelayer to the map using the map's addLayer method
   e.g. map.addLayer(mapservicelayer);
-------Here is the revised code------
<head>
  var gmap = new GMap2(document.getElementById("gmap"));
  var mapservicelayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://0.0.0.0(myliveip)/ArcGIS/rest/services/javatest/admin_boundries/MapServer",{"opacity":0.75});
</script>
</head>
</body>
</html>
