Python Script to List Visible Layers in Multiple MXDs?
1085
06-05-2020 12:10 PM
KaceyBurton
Afternoon all,
I have about 50 mxd's I need to go through and export all active layers in the maps to a new geodatabase.
I've reviewed some of the online arcpy functions and have tested the ListLayers script. However, does anyone have a good script to recurse through a directory of MXD documents, find only those layers that are currently checked on in each map, and export them to a new geodatabase?
I'm also a bit of a novice to python scripting. Any help would be greatly appreciated!
JakeSkinner
Esri Esteemed Contributor
Hi Kacey,
I haven't tested, but you could use something similar to below:
import arcpy, os
# Directory that contains MXDs
arcpy.env.workspace = r"C:\Projects\MXDs"
# Get list of MXDs
mxds = arcpy.ListFiles("*.mxd")
# Iterate through all MXDs
for mxd in mxds:
    print("Processing {0}".format(mxd))
    # Create MXD object
    mxd = arcpy.mapping.MapDocument(os.path.join(arcpy.env.workspace, mxd))
    # Get Data Frames
    dfs = arcpy.mapping.ListDataFrames(mxd)
    # Iterate through each layer in each dataframe
    for df in dfs:
        for lyr in arcpy.mapping.ListLayers(mxd, "*", df):
            # If layer is visible print layer name
            if lyr.visible:
               print("\t" + lyr.name)
