Repeat aggregate function - blank repeat values
1114
5
03-10-2020 03:27 AM
ClaireWood
I have an issue with the repeat aggregate function in relation to repeats.
My survey uses repeats, and sums the total within each repeat using the aggregate function e.g. sum(${repeat_value}).  Each of these totals is then summed in a single calculation e.g.   sum(${repeat_value1})+sum(${repeat_value2})+sum(${repeat_value3}).
However, in Connect version 3.7.62 and Survey123 v. 3.7.57, a record is no longer automatically created within a repeat, hence the formula above no longer works, unless a blank record is created in the repeats.  This is OK in some instances (we just need to make sure users add a record in the repeat), but in some scenarios, the repeat is hidden because it is not relevant.
So, is there a way of automatically creating a record in a repeat?
Or is there a work around to get the formula above to work in order to sum all values in a set of repeats?
Thanks!
Claire
Partly related to issue: https://community.esri.com/thread/214756-bug-with-repeat-aggregate-function
by Anonymous User
Not applicable
Hi Claire,
Can yo please provide a copy of your xslx file for this survey so we can take a closer look?
Thanks.
Phil.
ClaireWood
Hi Phil,
Can I email you the XLSX?  It's too big to attach.
The problem occurs on page 3 (a Plot Type must be selected (choose either X or P) on page 1 and Plot Recorded must be 'Found' on page 1).
The issue occurs where the plot type is set to 'P' or 'X' - the 'Total Cover' does not appear until at least 1 record has been entered into all of the repeats.  (I've worked around the issue of the total not appearing because of hidden repeats by creating a separate total where plots are not 'P' or 'X' - these were types which had hidden repeats).
Hope this makes sense.
Thank you! Claire
by Anonymous User
Not applicable
Hi Claire,
Yes, please email me the xlsx file, do you have my email address from previous communications?
Regards,
Phil.
ClaireWood
Hi Phil,
I don't seem to have your direct email - can you let me know?
Thank you!
Claire
by Anonymous User
Not applicable
Hi Claire,
I just sent you a private message with my email address.
Regards,
Phil.
