ArcGIS Pro 2.5: How to label features based on two fields with each label on a separate line?
19468
13
02-28-2020 10:50 AM
JamalNUMAN
Legendary Contributor
ArcGIS Pro 2.5: How to label features based on two fields?
For example, in ArcMap features can be labeled based on two fields such that labels can aligned vertically by using the expression below:
[Male]  & vbnewline & [Female]
How this can be performed in Pro?
Jamal Numan
AhmadSALEH1
 Honestly, I was mixing the Labels expressions with Field calculator operations!
in the Field calculator, there is no VBScript option anymore! but in the label expressions, it's still there and you can use it as the following.
"Area A: "& [Area_A] & vbnewline & "Area B: "&[Area_B] & vbnewline & "Area C:"& [Area_C]
If you decided to use python here is how you can do it, but again I was under the assumption that the label expressions behave exactly as the field calculator;  this is why I suggested using "!" instead of []  which was wrong.
here is the correct way to do it:
def FindLabel ( [Area_A], [Area_B], [Area_C] ):
    mylabel="Area A:"+[Area_A]+"\n" +"Area B: "+[Area_B]+"\n"+"Area C: "+[Area_C]
    return mylabel
Or a more concise method by using .format to concatenate the string  as Dan mentioned in his post
def FindLabel ([Area_A], [Area_B], [Area_C] ):
    return "Area A:{}\n Area B:{}\n Area C:{}".format([Area_A], [Area_B], [Area_C] )
DanPatterson_Retired
check on the advanced checkbox
JamalNUMAN
Thanks Dan.
But what is the code that lets the labels appear vertically instead of horizontally?
def FindLabel ( [Male], [Female]):
    return "{}, {}".format ( [Male], [Female])
Jamal Numan
"{},\n{}"  plus the rest
\n is the newline in python
JamalNUMAN
Thanks Dan.
The code is below:
[Male] + "\n" + [Female]
Jamal Numan
JamalNUMAN
The code below is useful
"Female:" + Text($feature.Female, '#,###') + "\n" + "Male:" + Text($feature.male, '#,###')
Jamal Numan
AhmadSALEH1
[Male] + "\n" + [Female] will not work becuase [] are vba expressions which is not used in Pro anymore.
if you are using python expressions use! instead of []
!Male! + "\n" + !Female!
Although, it looks like Arcade has more potential in Pro.
JamalNUMAN
Many thanks Ahmad for the elaboration
I would appreciate if you provide me with the code that labels my feature class with the format shown in the screenshot below. The feature class is attached
Jamal Numan
AhmadSALEH1
    return mylabel
As shown in my post... https://community.esri.com/thread/249062-arcgis-pro-25-how-to-label-features-based-on-two-fields#com...
which is another reason not to type what you think is the field formatter, but to select the fields from the list of available fields
