Change default value when updating record
1603
02-18-2020 11:04 AM
BradySmith
I am trying building a web app that uses survey123 to edit existing trail feature in the web browser by appending the "?mode=edit&objectId=1" to the survey url. I was able to open and edit existing records but I was hoping there was a way to auto update a couple of the fields. Is there a way update fields automatically for the user? For example, users can edit records that exist and have a status of "Available" but when submitted, the record status would change to "Pending" and record when the form was first filled out.
JamesTedrick
Esri Esteemed Contributor
Hi Brady,
Passing values via the field:<FIELDNAME>=<VALUE> parameter should update the values of the form.  Also, please note Ismael's recent post regarding an upcoming change to the mode=edit behavior: Upcoming changes to Survey123 web form's query parameters
