Survey123 Populate a cell based on a previous choices list.
931
02-18-2020 10:36 AM
TrevorRobar2
Hey Gang,
In a column, I have a select_one function from a choices list of 45 string values. I am trying to populate a cell with an integer value based on this first choice. from a second choices list.
The first Choice list looks like this;
LotAcadia Street West (6)Acadia Street West (6) - 12
The second choice list looks like this;
LotnAcadia Street West (6) - 12
12
I can build out a series of If statements (45 in Total), but just wondering if I can populate the second field with an integer from the second choice, based on what I chose from the first Choice List.
Hope this makes sense.
T.
JamesTedrick
Esri Esteemed Contributor
Hi Trevor,
Typically, you would use the integer value as the name value of the list, which would get you the value directly.
