ArcGIS Pro: How to set the default unit for map to be in meter,
5555
28
02-08-2020 12:14 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to set the default unit for map to be in meter
Jamal Numan
DanPatterson_Retired
Project, properties under Units
JamalNUMAN
I selected the Meter option but Pro gets back to Feet in its own!
Is this a bug?
Jamal Numan
what are your location units?  you might want to check them all Jamal
JamalNUMAN
I tried meter for the “distance units” and “location units” and they both get back in their own. Is this a bug?
Jamal Numan
put something in the map so it has data to work with
JamalNUMAN
I’m referring here to the default unit as a new Map is inserted. Why should I have layers to get the “meter” worked?
Jamal Numan
JamalNUMAN
There should be a bug here! As the “distance units” and “location units” are set to be “meter”, they get back to the native default in their own!
What cloud be the issue here?
rawan saleh
Saleh Ahmed
Jamal Numan
The example I showed was for setting them both and it worked in ArcGIS Pro 2.5
