Button user input doesn't work with line data.
1111
01-29-2020 04:51 PM
NathanJohnson
We have a button that starts a track log (line data). We cannot configure button user input for the line data. We've tried multiple data types (coded values, single line text, etc). Everything seems fine in Designer, including glancing at the JSON. When you open the project on a mobile device to capture data, and click on the button to begin taking a line, there is no pop-up dialogue box to enter the button user input data.
We've tested this a bunch, including using different line feature layers. Button user input isn't working with any line feature. However, button user input can be configured successfully for point data in the same project. We haven't tried with any polygons.The projects we've tested all populate data into a single hosted feature service. I believe the feature layers are all set up appropriately.
We also tested project user input for line features and it works as expected.
Any ideas?
Tags (1)
Mandy_Li
Hi Nathan,
If a button user input is successfully configured, it will pop out the user input dialog when you finish (end) collecting the line feature. Did you see the input dialog when you tap the button again to end it? If you still see this error, would you mind sharing the project with our dev team to take a closer look?
To do this, in ArcGIS Online create a group and share the project and layers with it. Then invite the following user to join the group: qccreator
Mandy
Mandy_Li
Hi Nathan,
Mandy
NathanJohnson
Aha, it does show up at the end. Thank you!
