Error Initializing form,failed to load data form
1616
01-23-2020 04:56 PM
BasilicTek
I am having trouble accessing my survey on the web. I think the problem is linked to my pull data function.
I can access the survey from the phone app but whenever I try loading the survey on the web I get a message box saying "Error initializing form, failed to load data form".
Anyone has had the same problem ? I made sure there were no special characters in my column name and I also removed all extra columns for the csv file, but I still get the error message.
thank you,
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Molina,
The issue has to do with the capitalization of 'SprayInfo' matching the filename exactly.  On lines 14 & 15, you refer to it as 'Sprayinfo' (note the lowercase i), which causes the error.
