Remove Map Image Layers when navigating content
1027
12-16-2019 08:01 AM
Amanda__Huber
MVP Regular Contributor
Hi QuickCapture Team,
When navigating though Feature Layer content Map Image layers also display. In the designer it's unclear which is the feature layer and if the map image layer is selected instead we receive an error message (please see images below).
Please either identify the Map Image Layer with an icon (and document that it cannot be used) or remove it completely from displaying in this content.
Thank you,
Amanda
JohnathanHasthorpe
Hi Amanda
As discussed, the designer filters out all items types that are not feature layers, image services will not be visible.
John
IsmaelChivite
Esri Notable Contributor
Hi Amanda. Thanks for reporting this. This is likely a software defect. Image Layers should not be displayed in this dialog. We will do some research on our end and post in this thread our findings.
JohnathanHasthorpe
Hi Amanda
John
Amanda__Huber
Thanks so much John & team for fixing this bug and resolving the issue. Much appreciated!
