ArcGIS Pro 2.4.2 Spatial Join using Hosted Feature Services returning Empty Attributes
715
12-04-2019 07:02 AM
KyleWikstrom
Have any experienced using ArcGIS Pro Spatial Join tool to join the attributes from one feature to another based on spatial relationship, gotten the output layer created with the correct attributes, but got all null values for the joined attributes when using layers added to the map as feature services? The coordinate systems are the same. This process works successfully using AGO Map Viewer and the appropriate Analysis tool, but not in ArcGIS Pro when I attempted.
Any other similar experiences, thoughts, or suggestions? Things I should be considering?
