Disable Creating Assignments in Dispatcher map for certain layers
871
11-15-2019 06:58 AM
BrianBulla1
Is it possible to show a layer (ie. parcel fabric) in the Dispatcher map, but disable the layer from being selectable??  Assignments are being created for Parcels, when they should only be getting created for the Address Point.
Kylie
by Esri Regular Contributor
Hi Brian - When you are editing the dispatcher map you can remove popups on the layer and it won't be selectable. When editing the map in Workforce, use the "Other Options" ellipses for the parcel fabric layer and click Remove Pop-up. Save the map, open the project, and you should no longer be able to select parcels.
Esri Education Team
Kylie
Esri Education Team
BrianBulla1
Hi Kylie Donia‌,
Thanks for the information.  That worked.  Just as an FYI, it does not work if you are using the BETA Map Viewer in AGOL, but using the regular Map Viewer all the changes were saved properly.
Thanks again!
