Multiple LayerLists In Web App
7162
15
09-05-2019 11:39 AM
RichardRhone
Is it possible to have more than one layerlist in one web app. I would like to add another layerlist where i can have only some of the layers visible in layerList1 and other layers visible in layerList2
RobertScheitlin__GISP
Richard,
  Through direct dom manipulation you can:
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1, maximum-scale=1,user-scalable=no"
    <title>LayerList widget - 4.12</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
        overflow: hidden;
    </style>
    <script src="https://js.arcgis.com/4.12/"></script>
    <script>
      require([
        "esri/views/SceneView",
        "esri/widgets/LayerList",
        "esri/WebScene",
        "dojo/query",
        "esri/core/watchUtils",
        "dojo/dom-style"
      ], function(SceneView, LayerList, WebScene, query, watchUtils, domStyle) {
        var scene = new WebScene({
          portalItem: {
            // autocasts as new PortalItem()
        var view = new SceneView({
          container: "viewDiv",
          map: scene
        view.when(function() {
          var layerList = new LayerList({
            view: view,
          // Add widget to the top right corner of the view
          view.ui.add(layerList, "top-right");
          //workaround for making sure layerlist is ready
          watchUtils.when(layerList, 'operationalItems.length', function(){
             var lis = query('li[aria-labelledby $= "__title"]', layerList.domNode);
             lis.map(function(li){
               if(li.innerText === "San Francisco"){
                 domStyle.set(li, "display", "none");
               if(li.innerText === "Growth Potential"){
          var layerList2 = new LayerList({
            view: view
          view.ui.add(layerList2, "bottom-right");
          watchUtils.when(layerList2, 'operationalItems.length', function(){
             var lis = query('li[aria-labelledby $= "__title"]', layerList2.domNode);
               if(li.innerText === "Transit lines in service"){
               if(li.innerText === "Transit lines planned"){
    </script>
  </head>
  <body class="calcite">
    <div id="viewDiv"></div>
  </body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Richard,
<!DOCTYPE html>
<html>
  <head>
    <meta
      name="viewport"
    <link
      rel="stylesheet"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
        overflow: hidden;
    </style>
    <script>
      require([
        "esri/WebScene",
        "dojo/query",
        "dojo/dom-style"
          portalItem: {
          map: scene
            view: view,
            view: view
    </script>
  </head>
  </body>
JohanArtica
Robert Scheitlin, GISP,
 What would be the way if the layerlist were inside an expand widget?
No difference. Same code would apply.
JohanArtica
I tried adding an expand widget, but I don't get it to work, what am I doing wrong?
<!DOCTYPE html>
<html>
  <head>
    <meta
      name="viewport"
    <link
      rel="stylesheet"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
        overflow: hidden;
    </style>
    <script src="https://js.arcgis.com/4.11/"></script>
    <script>
      require([
        "esri/WebScene",
        "esri/widgets/Expand",
        "dojo/query",
        "dojo/dom-style"
      ], function(SceneView, LayerList, WebScene, Expand, query, watchUtils, domStyle) {
          portalItem: {
          map: scene
        container: document.createElement("div"),
        view: view,
      var layerListExpand = new Expand({
        expandIconClass: "esri-icon-layers",
        expandTooltip: "Operational Layers",
        view: view,
        expanded: true,
        content: layerList
      view.ui.add(layerListExpand, "top-right");
         /* var layerList = new LayerList({
            view: view,
          view.ui.add(layerList, "top-right"); */
            view: view
    </script>
  </head>
  </body>
</html>
Johan,
  OK, I see the issue is the dom node the query needs to work with is now the expand widgets dom node:
var lis = query('li[aria-labelledby $= "__title"]', layerListExpand.domNode);
Instead of the layerList.domNode
RichardRhone
I am trying with the expand but not getting the desired result :
var layerList2 = new LayerList({ view: view, container: document.createElement("div"), listItemCreatedFunction: function (event) { item = event.item; item.panel = { content: "legend" }; } });
var expandLyr = new Expand({ view: view, content: layerList2.domNode, expandTooltip: "Layers With Legend", collaseTooltip: "Layers With Legend", expandIconClass: "esri-icon-layers" });
view.ui.add(expandLyr, "bottom-right");
watchUtils.when(layerList2, 'operationalItems.length', function ()
setTimeout(function ()
var lis = query('li[aria-labelledby $= "__title"]', expandLyr.domNode);
console.log("LIS ", lis);
lis.map(function (li)
 console.log(li.innerText);
}, 0)
Results :
Notice that only subs have a innerText. How do I get around this as I need to remove these from the layerList
I do not have this issue with the layerList by itself; only with Expand
RichardRhone
Issue resolved by putting the code outside view.when()
JohanArtica
Robert,
I'm sorry to bother you again with my inconveniences, but when the expanded property is changed to false, in the expand widget, it doesn't work properly, do you know why this happens?
because when the expand is hiding the layerlist then the query can not find the nodes it is searching for. You will have to watch the expand to see if it is expanded before you execute the query code.
