Failed to Open Model
5752
5
08-29-2019 01:31 PM
JacksonLane
I'm working on my model in modelbuilder when suddenly ArcGIS freezes and crashes.  When I open it back up, I get this error message when I try to open my model:
Failed to Open Model Error Message
I've tried copying the model, moving it to another toolbox, and using a different computer.
How can I recover my work?
Tags (1)
curtvprice
I know of no tools that can recover corrupt tbx files (along the lines of MXD Doctor).
ThomasColson
Try naming the toolbox and model something other than "New Toolbox" and "Model", and put it on C temp, not on a network share. I have a hunch here.....
JacksonLane
I  still get an error after copying to my Default toolbox on my C drive.  I can open other models on both my network and local drives.
I still get an error after copying to my Default toolbox on my C drive.  I can open other models on both network and local drives, but not this one.
curtvprice
NLI_Wendy
This is the solution??
ptanimoto
I have the same issue. ArcGIS Pro fails to open models even though they are stored locally and were configured only with local data.  Losing a model can be devastating. Even if data are moved, the model framework should persist.
