Excel Report failure because of Process Counter
2004
08-28-2019 07:27 AM
AlexandreGAILING
hi
The excel report generation fails on my Monitor 10.7.1 with the following message:
{"error":true,"message":"Traceback (most recent call last):\r\n  File \"ExcelReport.py\", line 12, in main\r\n  File \"Outputs\\OutputBuilder.py\", line 28, in __init__\r\n  File \"Outputs\\RunMethods.py\", line 60, in RunMain\r\n  File \"Outputs\\RunMethods.py\", line 292, in _RunProcess\r\n  File \"Modules\\Process\\ProcessMemVirtual.py\", line 11, in __init__\r\n  File \"Modules\\Process\\ProcessMemVirtual.py\", line 25, in BuildModule\r\n  File \"Modules\\Process\\ProcessMemVirtual.py\", line 36, in SetModuleData\r\nTypeError: unorderable types: NoneType() >= int()\r\nERROR:root:None\r\nTraceback (most recent call last):\r\n  File \"ExcelReport.py\", line 12, in main\r\n  File \"Outputs\\OutputBuilder.py\", line 28, in __init__\r\n  File \"Outputs\\RunMethods.py\", line 60, in RunMain\r\n  File \"Outputs\\RunMethods.py\", line 292, in _RunProcess\r\n  File \"Modules\\Process\\ProcessMemVirtual.py\", line 11, in __init__\r\n  File \"Modules\\Process\\ProcessMemVirtual.py\", line 25, in BuildModule\r\n  File \"Modules\\Process\\ProcessMemVirtual.py\", line 36, in SetModuleData\r\nTypeError: unorderable types: NoneType() >= int()\r\n"}
on windows 2012, monitor 10.7.1, chrome 76
from my tests, this is due to the "process" counter : the VirtualGB value is allways empty.
how can i troubleshoot this?
AlexandreGAILING
i found my issue was related to the fact that i didn't have enough OS access to see Memory in the process counter ... fixing this this solved my problem. That said, i did not expect that a simple 'blank' value on a counter was able to cause such a behavior.
ShreeRajagopalan
Alexandre GAILING‌ Please reach out to Esri Technical Support in order to resolve the issue you are experiencing.
by Anonymous User
Not applicable
Hi Alex,
To test please use native tools such as perfmon prove it rather than ArcGIS Monitor Administrator as this is independent verification.
  • Open perfmon at  your machine (where AGM installed), add counter using your machine "arcgismonitorservicetestsrv"
  • add the Process counter you want to monitor and if it works fine means that the issue is at ArcGIS Monitor configurations.
Hope this will help you to figure out whether the issue is ArcGIS Monitor or the native issue.
Manoj
AlexandreGAILING
ShreeRajagopalan
Glad to hear that! I will mark this as solved. Please reach back out if that's not the case.
