Unable to instantiate class for xml schema type: ArrayOfCIMMapScale
6584
7
08-08-2019 02:43 PM
ClintonBallandis1
Hi all,
I'm getting the following Severe Error in my ArcGIS server (10.6.1) logs.
Any ideas of what the Unable to instantiate class for xml schema type: Error is and how to resolve it ? The error code is 50000 I can't seem to find this in the Server Error Codes?
Clinton
TanuHoque
Clinton Ballandis‌ we need to take a look at what is going on. could you pls go thru support and submit a bug with reproducible steps?
JulieK
Did this issue get resolved? I get the same error in the log
by Anonymous User
Not applicable
I am also receiving this error message in the log of ArcGIS Server as a severe error although there is not any problem in publishing the services. I published hosted feature services by getWebLayerSharingDraft and CreateWebLayerSDDraft and compared these two functions. I know that getWebLayerSharingDraft is the newest version and has more capabilities, but it looks like that this function causes severe error in ArcGIS Server not the other one. I just want to be sure that this does not make any issue in future.
Thank you
Kimia
TanuHoque
Hi Kimia,
Could you pls reach out to Esri support and give us exact repro steps, data? We will take a look at this.
Thanks.
Tanu
by Anonymous User
Not applicable
Thanks Tanu. I reached out Esri technical support team and they helped me to figure out the issue. I want to share the results with the community. After testing and reviewing the publishing process, we found out that defining "staging_version" for hosted feature services in arcpy.StageService_server() causes this error message. Based on stage service document, "staging_version" is optional in this function and its default for feature services is 5. Therefore, there is not any need to define it in the function again. I removed it from my Python script and did not receive any error message in ArcGIS Server log.
I would like to thank Esri technical support team for their great help.
Thank you
Kimia
JoeBryant1
Hi Kimia,
Thanks for sharing this with the community. Did you have to republish the service, or could you update the existing service definition to stop this error?
Martin1
Thanks for the solution. I had the same error, but with your workaround it is all good now.
