WMS - random numbers added at the end of a layer name when using special characters or spaces
1314
12-05-2022 06:22 AM
Gisfunk
When publishing a service on servers running on arcgis 10.8, the layers names on my wms service have random numbers at the end, when i publish the same service with taking off the special characters and the spaces from the layers names on my mxd, everything is fine.
Thing is, i want my layers with these characters but without the random numbers at the end.
I didn't have this problem with 10.3.1
Thank you !
DavidLight
I have seen similar behavior when publishing or overwriting services using a cache.  Could your problem be related to caching?
Gisfunk
Hi ! Thanks for the answer, actually, I tried publishing a new service with a new layer with a name that has special characters. So no overwriting and I still had the same problem, problem that I didn't have with 10.3...
MarkChilcott
I am seeing the same thing in 10.9.1 (upgrade from 10.6.1).
Was there a solution to this?
