System Log Parser for ArcGIS in Monitor 10.7.1
1813
08-07-2019 06:55 AM
DianeMcGuerty1
System.Exception: An error occurred during log collection: The required Token Service URL was undefined. Please ensure the Token Service URL is defined at ESRI.PS.EIST.SystemLogParser_Plus.CLI.StartHere.Main(String[] args). Do I need to update the Tokens to :
{ "type": "BUILTIN", "properties": { "allowHttpGet": "true", "allowHttpPostQueryParams": "true", "longTimeout": "1440", "sharedKey": "VYHyatfGUlFWHgnAVMEc40nL1rn7s+l190vtgMjCx3c=", "shortTimeout": "60" } } ??
Thanks-
JohnGraham2
Hi Diane,
Check the token url such as (https://serverhost.domain.com:6443/arcgis/tokens/generateToken) works in a browser and can successfu...ate a token. There should be no need to manually edit/update the token config (JSON). If the token is generated, it should allow System Log Parser to access the logs. Also check the ArcGIS Server url such as (https://serverhost.domain.com:6443/arcgis) is accessible from the machine running System Log Parser ...
Hope it helps. If you need more assistance with System Log Parser, Esri Professional Services offers consulting support.
Best Regards,
John
JohnGraham2
Hi Diane,
Best Regards,
John
