Seeking datasets that has the degree, minutes and seconds world longitude and latitude
4640
14
08-02-2019 06:20 PM
DEAF_PROBERT_68
Honored Contributor
I am seeking a GIS datasets that has the longitude and latitude that I really need badly that has the degrees, minutes  and seconds .... I am aware that there is 1 degree, 5 degree, 30 degree and 45 degrees.... I do not want them...
Where do I find them ? I have looked around on the internet and didn't find it.... Does ArcGIS Pro come with it ?  How about ArcGIS Desktop ?
Yes I know that ArcGIS has its own Longitude and Latitude but I really want the datasets...
DanPatterson_Retired
coordinates are recorded in decimal degrees in Arc* not DMS.  Are you looking for a grid at a fine scale for an area so show DMS on the border of layout? or are you looking at converting DD coordinates to DMS? in a table>\?
Convert Coordinate Notation—Data Management toolbox | ArcGIS Desktop
DEAF_PROBERT_68
Honored Contributor
Oh...yes I mean the arc* . No, I don't want to convert them.
DEAF_PROBERT_68
Honored Contributor
Dan,
No I am not crazy about that but I need the dataset because I am doing georeference and the scanned map has it there...that is why I asked about it...
JoshuaBixby
MVP Esteemed Contributor
DEAF_PROBERT_68
Honored Contributor
That is interesting but I think it will take me some time to make this work... Have you tried this in the past, friend ?
JoshuaBixby
Yes, with ArcMap, but I haven't tried the tool in Pro.  I assume it is very similar.  You could also just use Create Fishnet—Data Management toolbox | ArcGIS Desktop, which doesn't generate as much in terms of output, but maybe a single grid is all you need.
DEAF_PROBERT_68
Honored Contributor
Well I found out, I myself did not realized that the Degrees, Minutes, Seconads datasets, will have almost 4 billion polygons worldwide...
So with that said, I will only need a small region area is what I need and not the whold world...
I will follow what other suggest me to do is create a Fishnet or make my own Grids and Gratticules Layer...
Thank you.
JoshuaBixby
I marked this question as "assumed answered" since it pertained to downloading a pre-existing data set.  If you have questions on using either of the tools suggested, you can start a new question.
DEAF_PROBERT_68
Honored Contributor
Sure I will. I will just have to go to YouTube and check them out ...
