Dynamic Binning Tab Not Enabled
2323
07-16-2019 12:28 PM
MeleKoneya
I ran the enable feature binning tool on a SQL Feature Class and see in the layer properties that Feature Binning is enabled.
However when I click on the layer with Feature Binning Layer enabled in the Contents Tab,   Binning is disabled
The data is in a 2D Map, but the message when hovering over "Binning",   a message says it Binning is Currently Disabled.  Bins cannot be displayed for layers in the 3D layers category
What am I missing here?
Mele
MeleKoneya
Simon,
You might start by taking a look at this to see if your data is supported.
https://pro.arcgis.com/en/pro-app/tool-reference/data-management/enable-feature-binning.htm
After struggling with this for quite a while,  I contacted ESRI support and they provided this bit of useful information.
What I did was to run the 'Enable Feature Binning Tool' on the point Feature Class in the Catalog View rather than in the Contents pane.     After binning was enabled,  I dropped the Feature Class onto a map and the binning tab visible and was enabled.
This also come from Support and might be of use.
One other caveat was that I needed to change my projection based on this "An equal area projection for your data is strongly recommended"
Here are a few additional reference web-links:-
- Introduction to Dynamic Feature Binning in ArcGIS Pro: https://www.esri.com/arcgis-blog/products/arcgis-pro/mapping/introduction-to-dynamic-feature-binning...
- An overview of the Feature Binning toolset: https://pro.arcgis.com/en/pro-app/tool-reference/data-management/an-overview-of-the-feature-binning-...
Mele
SimonJackson
  • Have enabled feature binning plus cache in Azure SQL (not a geodatabase)
  • Layer properties says its enabled
  • However, unlike your screenshot, I don't even get the greyed out icon.  Nothing.
MeleKoneya
Simon,
Mele
