Hide a point layer in web appbuilder forcing user to use filter widget to view points
2431
7
07-04-2019 02:27 AM
KymMcDonagh
Hi we have a point layer displaying on our web appbuilder application. At present we use the filter widget to view points that fall under certain categories. The user can still however see all the other points. Is there a way to hide the points layer from users so are they are forced to use filter widget. When they search using the filter widget the points under the filter search are then displayed only while all other points remain hidden.
Paula
RobertScheitlin__GISP
Paula,
  You could use the Query Widget or eSearch widget instead they do not require the layer to be part of the web map so if it is not then you just query/search for what you want and the results layer is added to the map.
Paula,
KymMcDonagh
Hi Rob thanks for getting back to me so quickly
I tried the esearch widget you created. It seems to work fine.
Just a couple of things
Is it possible to label the result point symbols. We want to be able to label the points by sequence.
Also we want to be able to export the results of the search to a csv which only shows limited fields.
With the query search I am unable to find a way to label the result point symbology. I am able to export the results to a csv but it displays all the fields in the attribute table. I only want users to be able to view and export a limited number of these fields.
Paula
KymMcDonagh
Hi Robert
I have been messing around with the esearch widget and seem to have solved my question about the attribute table.
My only question now is regarding labeling the symbology of the points so the user can view the order of their sequence
Paula
Paula,
   I am not aware of any widget that currently supports sequential labeling of results.
KymMcDonagh
Hi Robert so is there no way of labeling the symbols full stop?
I do not have any support for labeling results in my widget. You are the first person that has ever asked anything about this in the many years I have had my eSearch available, so pretty uncommon request.
KymMcDonagh
Ok thanks for your help with all this Robert
Very much appreciated
