Has anyone encountered Error 500 ("The service is locked because it is modified by another thread") while publishing?
3038
10
06-25-2019 09:31 AM
JimPugh2
JimPugh2
Error 500
JimPugh2
When nested repeats were removed, it published without an error. Repeats were nested 2-levels deep. Documentation says you can have any number of nested repeats. What gives? ~JP
DougBrowning
MVP Esteemed Contributor
Are you maybe still using a older Connect version?
JimPugh2
Version 3.3.5.1.
JamesTedrick
Esri Esteemed Contributor
Hi Jim,
This is an unusual error- based on the message and where it occurs in the publishing sequence it appears to be occurring during a set of operations that occur after the feature service is initially created (when the fields and related tables are added or when editor tracking is enabled).  Can you share the XLSForm (if not publicly, please e-mail jtedrick AT Esri.com) so that we could attempt to reproduce?
Neil_Young
James,
Were you able to identify what causes this error? We have some fairly complicated forms with nested repeats that have published successfully and suddenly after a handful of changes one of them it refuses to publish and provides this error. Our teams need to get in the field in a couple days, so we really need to get this resolved and any insight you can provide would be appreciated.
JimPugh2
We were not able to resolve the issue. We ended up removing the nested repeats. I suspect changes to the S123 app will make it easier... maybe.
pat_algura
Has the reason for this error been identified? I have a survey with repeats (not nested repeats). I added new fields to the form outside the repeat and tried to publish it. The initial publish didn't push through as it's been taking so long, so I force closed Survey123 Connect and tried to publish again but got this error.
Pat
AnupNair
We are also facing the same issue. Have you found any solution for this?
 Thanks in advance
