Screening widget broken 2.12
1708
7
05-09-2019 08:41 AM
by Anonymous User
Not applicable
The screening widget will not instantiate in WebApp Builder 2.12 Developer Addition. I called Support, working on getting a NIM.  I tried plain vanilla hosted online ArcGIS Online with a service from a 10.6.1 server and same thing, Screening widget will not work. I do no configuration, just leave it as-is so when it comes in it has all the fields. Left everything default, but will not start up in the new WAB.  It was working however in 2.9 WAB DE. I want to use it to have a sweet printout for parcels. For that it's perfect. Anyone else have success getting Sreening Widget working on WAB 2.12?
Example app: https://sagis.maps.arcgis.com/apps/webappviewer/index.html?id=8fa594068d7c422eab9eaece45424610
by Anonymous User
Not applicable
It's assigned BUG-000122423 bug id.
And when I add the widget from 2.9 in it works. In 2.12  in console it says couldn't declare a function, if it wasn't a featurelayer. WAB dev team check Console on 2.12.
From the hosted app...
.... addFeatureLayer:function(a){"esri.layers.FeatureLayer"!==  ........
TypeError: Cannot read property 'declaredClass' of undefined
at Object.addFeatureLayer (Widget.js?wab_dv=2.12:156)
at Object.<anonymous> (Widget.js?wab_dv=2.12:156)
at init.js:64
at Object.forEach (init.js:72)
at Object.setFeatureLayers (Widget.js?wab_dv=2.12:156)
at Object._setFeatureLayersForSelectTool (Widget.js?wab_dv=2.12:137)
at Object.postCreate (Widget.js?wab_dv=2.12:127)
at Object.create (init.js:356)
at Object.postscript (init.js:355)
at new <anonymous> (init.js:201) "TypeError: Cannot read property 'declaredClass' of undefined
at Object.addFeatureLayer (https://sagis.maps.arcgis.com/apps/webappviewer/widgets/Screening/Widget.js?
etc....
So for now I'll just use the 2.9 widget.
SeanCurran2
Did you ever get a response to this problem? I am having the same issue, but it seems to only happen when I try creating an app in Portal. When I create a web app in WAB using ArcGIS online it seems to work just fine.
by Anonymous User
Not applicable
I used the old Widget. No... no response.  They deploy first to AGOL so they apparently fixed it now in the latest version.
by Anonymous User
Not applicable
I'm also getting this error trying to set up the screening widget on Portal.  Any follow ups?
by Anonymous User
Not applicable
Hi Kelly, in the short term, I think the only thing you can do is swap out the widget for the earlier version of it (2.9) that doesn't have the bug. No response yet.
by Anonymous User
Not applicable
I wonder if this is fixed in Enterprise 10.8 which has a newer version of WAB....may try upgrading our system.  I'll let you know.
SamanthaOsborne1
Any news on this the widget I am using 10.9.1 and the widget does not seem to work correctly.
