Select widget not returning all records
1572
06-25-2021 10:00 AM
Labels (2)
RandyMcGregor3
I have a layer with about 55,000 records in a web service. I have set the maximum number of records returned for 100,000. This layer is in a web map in web app builder.
In web app builder, I can see all records and export them from the attribute widget. If I select all records with the select widget, I get a total of 8,000 results in one environment, and a total of 24,000 results in a different environment. I don't know what is imposing this inconsistent constraint.
Is there anyway to ensure the select widget is selecting all records? In this case, it should always return 55,000 records when all features are selected no matter what computer I'm using.
Thank you,
Randy McGregor
LetíciadAgostoMiguelFonseca
Hi!
Have you sort it out? I have the same issue!
RandyMcGregor3
No, I didn't. I used the 'screening' widget instead. Slightly clunkier (more steps involved) but it selects everything. Screening widget—ArcGIS Web AppBuilder | Documentation
