Conditional statement for select_one and select_multiple in report template
4433
10
05-07-2019 02:10 AM
Environnement_1Lausanne
Is it possible to integrate conditional statement for select_one and select_multiple fields in a report template for a Survey123 report ?
If yes, what is the synthax ?
If no, is it planned as a future feature and when is the release planned for ?
Thanks a lot,
Hello, this works great in the XLSform to build the survey but not in the template for the report.
But I found the solution for the report template :
${if ((weather | selected: "other"))} The weather was ${weather_other}${/}
Have a good day !
BrandonArmstrong
Select_one and select_multiple questions questions work the same as other question types when using if statement syntax in the report template.  So, for instance, let's say you have a select_one question with a field name of 'severity' that asks, "select severity of incident" and your choices are low, medium, high...the syntax would look like the following
${if severity=="high"}${followup_question}${/}
This will show the value from 'followup_question' only if 'high' has been selected for the preceding select_one question named severity.
Try this out and let me know if you have questions.
Best,
Brandon
Hello Brandon,
Thank you for the answer Brandon. I tried to replicate exactly your recommendation but it still doesn’t for me.
For instance, if I have :
type
name
select_multiple weather
weather_type
With the following choices :
list_name
name
label
weather
good
Beau
weather
rainy
Pluvieux
weather
cloudy
Nuageux
weather
other
Autre
And if I have in the report template :
${if weather_type=="other"} The weather was ${weather_other} ${/}
Unfortunately, the conditional statement doesn’t work.
Do you have any idea why this is happening ?
Best regards
BrandonArmstrong
It looks like you have a space between ${weather_other} and $[/}.  Please remove this space, try again, and let us know your results.
I made the change but it still doesn't work.
Do you have another hint ?
Best,
BrandonArmstrong
Can you please try this with a value different than 'other' and let me know your results?
I tried and unfortunately it still doesn't work.
DougBrowning
MVP Esteemed Contributor
With select_multiple you have to use selected() not ==.
selected(${Customers},'Other')
https://community.esri.com/thread/184917-relevant-field-syntax-for-multiple-choice-questions
Have a good day !
ryanEvanczyk
Hi Brandon,
I have a select_one question with 3 possible responses. This questions cues a text field for "description" if 2 of the 3 responses are selected. I'd like the feature report to do the same - show the description, but only if choice1 or choice2 are selected. How do I write the syntax to show the description for 2 of 3 selections from my select_one?
${if select_one|selected:"choice1,choice2"} doesn't give a syntax error, but doesn't show the value in the report.
${if select_one|selected:"choice1","choice2"} gives a syntax error.
${if select_one|selected:"choice1"}or${if select_one|selected:"choice2"} with ${/}${/} at the end to close both gives no syntax error, but only shows the word "or". If you remove the "or" you just get nothing.
Thanks for the help,
RyanE
