Can I use Control Points?
1958
05-01-2019 07:44 AM
WEIPadI
I'm new to drone2map and testing it out.  I see how to add GCPs, but how do you identify/create check points?  I've done a bit of googling and haven't found an answer yet.  My experience is primarily with Agisoft Photoscan/Metashape, but I understand Pix4D allows for CPs.
Doug
CodyBenkelman
Doug
Drone2Map 2.0 will be released in June of this year, and it has full support for declaring control points as check points, to withhold them from the photogrammetric processing and then generate an accuracy report after processing.
Unfortunately the 1.x versions don't have explicit support for check points, so it requires a manual process of measuring the check points and calculating the accuracy statistics.
Cody B
CodyBenkelman
Doug
Cody B
WEIPadI
Any other new 2.0 features you can share?
