I would like to produce a map like this:
I have a spatially enabled data frame with a column with numeric values (integers). I want vary the size of the symbol by value. I have found documentation for changing colors, which works fine, but I can't figure out how to change size.
Here is my current code:
red_rel.spatial.plot(map_widget= m3,
renderer_type = 'c',
method='esriClassifyNaturalBreaks',
class_count=20,
col='MARK_Red')
I imagine it is a matter of changing the 'c' in renderer_type to something else but I haven't figured out what that is. There should also be a way to set a size range.
Many Thanks.
also, is there a way to clear the symbology so each time I run the script it doesn't just overwrite the previous symbology?
ArcGIS API for Python v. 1.6
Jupyter Lab v. 0.35.4
