Display number of view in operation dashboard
2994
04-10-2019 08:07 AM
DambéSANWOGOU
Hello, is it possible to display the number of views of an application in operation dashboard ???
Best regards
Anselme
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi Anselme,
> ... is it possible to display the number of views of an application in operation dashboard ?
Are you specifically referring to apps that are hosted/stored within an ArcGIS Online organization? or something else?
If you are wanting to display the number of views for apps that are hosted/stored within an ArcGIS Online organization, you'll likely have to write some custom python scripts to query the ArcGIS REST API, and possibly query for the number of item views. Then write this info into a custom feature service. You could then access the feature service's content in Operations Dashboard. I have not done this personally, but I think it is possible.
Another user did something similar to monitor user activities in an enterprise geodatabase, see this Linked In post:
Esri Database Monitoring Dashboard
Hope this helps,
DerekLaw
Hi Anselme,
Hope this helps,
DambéSANWOGOU
Thanks Derek Law , is it possible to display this result on the ArcGIS Online home page.
Best regards,
Anselme
DerekLaw
Hi Anselme,
Apologies for the late reply. I've been out of the office on vacation.
> ... is it possible to display this result on the ArcGIS Online home page
Customizing the appearance of the ArcGIS Online home page is limited, but possible. Please take a look at
Hope this helps,
