Start-up page for an ArcGIS Pro add-in
1558
04-08-2019 06:54 PM
JaewonYang
I have to build an add-in for ArcGIS Pro, I know that I have to use Pro SDK. But for start up I need an exe file that initiate a process to ask for required layer files to be loaded, when I give the files these files automatically open in ArcGIS Pro within a new map project.
What should I do for this? I can make an add-in but how do I make an exe file that starts ArcGIS Pro on click? does the Runtime SDK supports this kind of functionality?
P.S: I am doing this on C# platform using VS 2017.
by Anonymous User
Not applicable
Hello Jaewon -
It sounds like an ArcGIS Pro "Configuration" might fit your needs.
Please see the following:
ProConcepts - Configurations
https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-Configurations
ProGuide - Configurations
https://github.com/esri/arcgis-pro-sdk/wiki/ProGuide-Configurations
Good Luck!
+ bill
JaewonYang
Thanks, Bill
I will try this and I would like to bother you if further help required.
UmaHarano
Hi Jaowon,
You should create a Pro Configuration. This is similar to an add-in but it allows you to customize Pro's start-up experience. Using a Configuration you will be able to show a custom start page when the application launches. In this custom start page, you can display a control to list your layers.  When the layers are selected, you can initialize a Pro session - a New Map in your case - with the layers selected.
Here are some links that can get you started with this:
1. ProGuide: Configurations
2. ProConcepts: Configurations
3. Configuration Samples:
https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Framework/ConfigWithMap
https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Framework/ConfigWithStartWizard
Uma
JaewonYang
Thanks, Uma
