Can't edit feature layer I own
739
03-13-2019 01:22 PM
JoeBorgione
I added a feature layer to a map, copied it and then saved the copy to 'my content'.  Now I'd like to edit my layer, and I can't.  I don't know why not.  Can someone clue me in?
Tags (1)
JoeBorgione
It's because it's not a hosted feature layer.  See image below.  Utah_BusStops_Mine is the layer I want to make edits to, and it's listed as feature layer as opposed to TestPicPoints which is a hosted feature layer....
KellyGerrow
Esri Alum
Hi Joe,
Is editing enabled on your non-hosted service? You can still edit with non-hosted services, but editing capability needs to be enabled on the server in ArcGIS Server or ArcGIS Enterprise.
-Kelly
JoeBorgione
Thanks Kelly.  The original layer I copied from is on AGOL, as is my saved copy.  I'll come back to it on Monday.  Take a look at my other post today:  https://community.esri.com/thread/230554-agol-where-are-my-geocoded-addresses  I wonder what you might add to that one. Old dawg learning new tricks on AGOL....
Kelly Gerrow
