How can I get a List of ALL TAGS in my Organization?
2153
03-12-2019 01:00 PM
AaronPaul5
We want to clean out unwanted TAGS from our ArcGIS Online Organization.
Can I use the Python API or something else to do this?
Thank you,
Aaron
Tags (1)
MunachisoOgbuchiekwe
Hello Aaron,
You can search by your organization id, then loop though all the items and print out the tags. Below is an example....
import arcgis
from arcgis.gis import GIS
gis = GIS()
search_result = gis.content.search(query="orgid: Your org id here", max_items = 100)
for item in search_result:
    print(item.tags)
Hello Aaron,
import arcgis
gis = GIS()
    print(item.tags)
AaronPaul5
Hi Munachiso,
Thank you for the easy to follow code snippet.
I am now trying to use the same code for Portal.
Should it work in portal and why doesn't it need credentials to get the tags?
Thank you again,
Aaron
BertramGilfoyle
this string is not working for me. does anyone have an update?
