Buffer Analysis using arcpy
4599
11-14-2021 10:14 AM
Abdulqadoos
I am looking for a piece of code which help me in converting my road centreline feature to a buffer. I have the following feature classes.
roads = "c:/base/data.gdb/roadcentreline"
roadsoutput = "c:/base/data.gdb/roadcentreline_Buffer"
Now, I want to convert this into buffer and store it in the roadsoutput. Any way to achieve this?
DanPatterson
MVP Esteemed Contributor
Did you see the code examples in the help?
Buffer (Analysis)—ArcGIS Pro | Documentation
... sort of retired...
ArcProOne
I would do something like:
temp = 'memory\\buffer'
arcpy.analysis.Buffer(roads, temp)
arcpy.management.Append(temp, roadsoutput)
arcpy.management.Delete(temp)
 and add all the other needed parameters to each function.
